probe-response
interface-config-radio-instance
Configures transmission
parameters for probe response frames sent by the access point in
response to probe requests received from clients.
Supported in the
following platforms:
- Access Points — AP3000/X, AP5010, AP310i/e, AP410i/e,
AP460i/e, AP505i, AP510i/e, AP560i/h, AP7612, AP7632, AP7662,
AP8533
probe-response [ac-strict|rate|retry|rssi-threshold]
probe-response rate [follow-probe-request|highest-basic|lowest-basic]
probe-response rssi-threshold <-128--40>
Parameters
probe-response ac-strict
probe-response ac-strict |
Strictly restricts sending of
probe-response frames to 802.11ac capable wireless clients. When enabled,
the radio will only respond to probe-request frames received from 802.11ac
capable clients. |
probe-response retry
probe-response retry |
Enables retransmission of probe-response
frames if no acknowledgment is received from the client.
This option is enabled by default. |
probe-response rate |
Configures the rates used for transmission
of probe response frames. The tx-rate options available
for transmitting probe response frames are:
follow-probe-request, highest-basic,
lowest-basic. |
follow-probe-request |
Transmits probe responses at the same rate
as the received request (default setting) |
highest-basic |
Uses the highest configured basic
rate |
lowest-basic |
Uses the lowest configured basic
rate |
<-128--40> |
Ignores probe request from client if the
received signal strength is less than the RSSI threshold
specified here <-128--40> – Specify
a value from -128 - -40.
nx9500-6C8809(config-profile-testAP510-if-radio1)#probe-response rate highest-basic
nx9500-6C8809(config-profile-testAP510-if-radio1)#probe-response retry
nx9500-6C8809(config-profile-testAP510-if-radio1)#probe-response rssi-threshold -60
nx9500-6C8809(config-profile-testAP510-if-radio1)#show context
interface radio1
